I have seen pictures where some of you have mounted a 66 or 110 block in a Leviton Structured Media Cabinet. Will a 66 or 110 block mount in the Leviton cabinet using the standard mounting holes or must you drill your own holes or mount it on a blank plate?
I just mounted my 66 blocks directly to the back of the can. I used some 3/4" nylon standoffs, so that there was space between the back of the can and the blocks. This way I could run wire beneth the blocks. You could achieve the same thing by using the standard mounting brackets that you can get for 66 blocks.
