Has anyone done any research and prep (I imagine HV only) for potential plugin hybrid cars?
(1) 15 or 20 Amp?
(2) 110 or 220?
(3) Outlets on the walls near the rear I guess?
(1) 15 or 20 Amp?
(2) 110 or 220?
I've thought about it. . I would think future proofing would entail running big enough Romex to allow 220 at high current. That would of course cover 110 or 220. You could even leave it behind the drywall until you decided it was needed. Leave the head end unterminated, also.
I'd run at least 8/3 romex to the garage, car location, etc. You don't need to terminate it at either end, but who knows what the requirement will be in the future. I'd imagine for compatibility it will be a standard 15amp 110V outlet, but better be safe than sorry. If you are buying the wire from a distributor it is pretty cheap.
 but absolutely, you'll want plugs in the garage.  Of course, assuming you've got wired power for the garage door openers, you can always just tap into those...
   but absolutely, you'll want plugs in the garage.  Of course, assuming you've got wired power for the garage door openers, you can always just tap into those...Ditto. I added 3 outlets, together on their own 20 amp breaker, just because I know some of the woodworking equipment I had was right at 15 amps, so it would have probably tripped a normal breaker.
Of course, right now, those outlets only run an extra fridge and freezer...but absolutely, you'll want plugs in the garage. Of course, assuming you've got wired power for the garage door openers, you can always just tap into those...
