beelzerob
I'm looking for a good solution for measuring water temp in a copper pipe, without having to open the pipe. This is the best thing I can find.
I was hoping I could use my secu16 analog inputs to measure whatever voltage this thing produces and convert that to a temp value. I just don't know how interchangeable these sensors and I/O things are.
The sensor link doesn't indicate what the voltage range is for that. I also realize that the secu16 only has an 8-bit A/D, so that's 255 discrete values...that should be enough. The sensors range is -10 C to 85 C, so that's an LSB of about a third C.
The sensor writeup however indicates that it's a digital sensor with a 12 bits resolution. Sooo...does this thing NOT produce a simple voltage from 0 to 4 or 5 like my other temp sensors I own do?
