Im curious about Infinitude - has anyone used it to be able to catch "freeze frame" type data?
Background: had an Infinity system installed over the summer (new AC, new furnace). After firing up the furnace once the gas line was run, all was well. A month later when we actually needed heat, I noticed the furnace would intermittently trip the high limit....at one point it did it enough times to cause the controller to bump it to max heat until the system was reset.
Contractor came out, tweaked the gas pressure settings a bit (lowered it to keep the temp rise to the lower end of the allowed range). Worked fine for a month, now it tripped again over the weekend.
What I would like is a way to log all of the data before during and after this happens, or even better yet just freeze frame the values when the limit is tripped. Static pressure (as calculated by the sytem), blower RPM, CFM, blower power draw, zone position, etc.
Has anyone done this? Is it possible to interpret the zone positions as well? (Im thinking my issue is duct related, but with 2 zones if Im not sitting there right when it happens, I dont know the state of the system when it occurs)
Thanks in advance.
-Chris
Thanks in advance.
-Chris
