Mike, you can give me a call sometime if you want. I'll be a safety net if you need it.
@ driven: The only item you really need to look at in the case of access control on the door is the physical hardware and it's operation. The rest, such as cut out, size, type, etc. can be worked around. In your case, the solution for the strike would be to get a thumbknob override on the hardware itself. Inside always free but outside locked unless overridden. What you don't do is have the door automatically unlock for an extended period, 3-5 seconds is plenty to say the least and you use the contact as the DSM (if you're not using an Elk KAM) to trigger the relock once the door opens.
After working on the first hundred doors or so it becomes much easier.
