Thanks for the update reminder.
In fact I just started to populate the enclosure last week. One of them is almost full and contains satellite tv distribution, intercom distribution, telephone distribution, and internet/intranet distribution. I used heavy duty velcro to secure the items into place. I really like the velcro as it makes it easy to pull things out quickly. My "lean expert" wife actually helped me with the organization of the enclosure, but it is nearly full and the biggest problem is the distribution of 120v ac. (It's good to get her involved so she can appreciate the complexities of something as seemingly simple as enclosure organization.) There are 2 outlets at the bottom which I plugged a power strip into, but almost every component has a clunky transformer plug in, so I think I can only plug 2 of them into the powerstrip. I just picked up some short power supply liberator cords today to see if those help.
In the other can I added the ELK-M1, which up until last week had been sitting in my office at work. I am currently running off a GE Concord security system now which is being monitored. In a few weeks when I know all the wiring is working, I'll have to rewire all the sensors to the elk-m1 and notify the monitoring company that I am ready to do the switch. Of course that voids the warranty on all the wiring and the old alarm system. The biggest gotcha with that is I will have to somehow extend all of the security wiring about 3 feet to reach the ElkM1. I'm not sure the best apprach for that yet.
Unfortunately the enclosures are made by GreyFox and none of the mounting holes match up with the Elk pins.
I installed the original 14x14 Elk enclosure in the garage which has cat5 running to it from the ElkM1. I also placed an outlet in the enclosure which is used to power a 24VAC .650amp transformer that I got at The Home Depot that drives the irrigation valves via an ELK relay board that is also in the enclosure. I ran the irrigation wiring though PVC down the garage wall and out the side of the house, then underground to the sprinkler valve solenoids. That's really the only thing the Elk is doing at this time.
I'm still trying to determine which lighting control system to go with. I got some new Insteon Dimmers which seem to work better than the old ones I had. But at this point I also want to check out the ViziaRF ZWave switches although they are more expensive but see to work in a more intuitive way. My ZWave knowledge is fairly low so I need to study up on it as well.
Then there is the missing home automation server (running CQC) that I need to get to do voice announcements and in the future provide a nice user interface to the home automation and theater systems among other things. You can see my CQC interfaces at
My CQC Templates
So it is coming along slowly, but as for the enclosures, I actually wish they were a little bigger if you can believe that. I also put locks on them for a little more security.
