Just received my ELK/CADDX stuff. I noticed that the ELK-73 speaker has stranded wire tinned at the ends. What is the recommended wire to run to the control panel? I will be running Cat 6e cable to the location where the speaker will be installed. Is it OK to connect the speaker wires to Cat 6e cable or should I run a separate 2 conductor wire for the speaker?
