Hello All,
I'm kinda confused right now. I want to connect my new PIR motion detectors to the ELK M1 gold, however the motion detectors has a tampered contact on it. I will be connecting the PIR to the panel with 4 wires conductors. this is what the PIR has (+ - NC C T T). so i know + and - is for the power. can i connect the yellow from the zone on the panel to the tamper connector on the PIR, the the green wire from the common leg on the panel to C on the PIR, then jump the other T to NC with a 2.2k ohm resistor? does this make sense? Can someone look at the two picture I attached. Which wiring diagram is correct? Thanks
