The keypad plugin cable has 6 wires. What exactly is the use for the blue and brown wire?
The instruction says the brown wire can be used for the 'Optional Programmable output from keypad'.....I am an extreme novice, exactly what does this mean?
The instruction says the blue wire is for the 'Optional programmable input "key pad zone"....what does this mean?...examples of what each of these two options do will help
I am using the M1DBH hub......I will be using the keypads to operate the ElkM1 board.
