Considering OpenHAB any other contenders?
I notice a number of people using it on the mysensors forum.  Can what's alluring about it be summarized in a sentence or two?  Or do I have to be inculcated through full immersion before I "get it"?
No David you do not need to be inculcated through full immersion before I "get it"
I know you like to tinker.  Pick an Openhab binding-plugin that suits your fancy and play.
All it will cost is your time.
     Bindings
        AlarmDecoder Binding
        Anel Binding
        Arduino SmartHome Souliss Binding
        Asterisk Binding
        Astro Binding
        Autelis Pool Control Binding
        BenQ Projector Binding
        Bluetooth Binding
        Bticino Binding
        CalDAV Binding
        Comfo Air Binding
        Config Admin Binding
        CUL Binding
        CUL Intertechno Binding
        CUPS Binding
        DAIKIN Binding
        Davis Binding
        Denon Binding
        digitalSTROM Binding
        DMX512 Binding
        DSC Alarm Binding
        DSMR Binding
        eBUS Binding
        Ecobee Binding
        EDS OWSever Binding
        eKey Binding
        Energenie Binding
        EnOcean Binding
        Enphase Energy Binding
        Epson Projector Binding
        Exec Binding
        Freebox Binding
        Freeswitch Binding
        Frontier Silicon Radio Binding
        Fritz AHA Binding
        Fritz!Box Binding
        FS20 Binding
        Global Cache IR Binding
        GPIO Binding
        HAI/Leviton OmniLink Binding
        HDAnywhere Binding
        Heatmiser Binding
        Homematic / Homegear Binding
        HTTP Binding
        IEC 62056-21 Binding
        IHC / ELKO Binding
        ImperiHome Binding
        Insteon Hub Binding
        Insteon PLM Binding
        IRtrans Binding
        jointSPACE-Binding
        KNX Binding
        Koubachi Binding
        LightwaveRF Binding
        Leviton/HAI Omnilink Binding
        Lg TV Binding
        Logitech Harmony Hub
        MailControl Binding
        MAX!Cube-Binding
        MAX! CUL Binding
        MiLight Binding
        MiOS Binding
        Modbus TCP Binding
        MPD Binding
        MQTT Binding
        MQTTitude binding
        Neohub Binding
        Nest Binding
        Netatmo Binding
        Network Health Binding
        Network UPS Tools Binding
        Nibe Heatpump Binding
        Nikobus Binding
        Novelan/Luxtronic Heatpump Binding
        NTP Binding
        One-Wire Binding
        Onkyo AV Receiver Binding
        Open Energy Monitor Binding
        OpenPaths presence detection binding
        OpenSprinkler Binding
        OSGi Configuration Admin Binding
        Panasonic TV Bindung
        Philips Hue Binding
        Piface Binding
        pilight Binding
        Pioneer-AVR-Binding
        Plex Binding
        Plugwise Binding
        PLCBus Binding
        Primare Binding
        Pulseaudio Binding
        RFXCOM Binding
        Sager WeatherCaster Binding
        Samsung AC Binding
        Samsung TV Binding
        Serial Binding
        Satel Alarm Binding
        Snmp Binding
        Somfy URTSI II Binding
        Sonos Binding
        Squeezebox Binding
        Swegon ventilation Binding
        System Info Binding
        TCP/UDP Binding
        Tellstick Binding
        TinkerForge Binding
        Tivo Binding
        VDR Binding
        Velleman-K8055-Binding
        Wago Binding
        Wake-on-LAN Binding
        Waterkotte EcoTouch Heatpump Binding
        Weather Binding
        Wemo Binding
        Withings Binding
        XBMC Binding
        xPL Binding
        Yamahareceiver Binding
        Zibase Binding
        Z-Wave Binding
    Application Integration
        Asterisk
        Google Calendar
        Linux Media Players
        ROS Robot Operating System
        Telldus Tellstick
        Twitter
        ZoneMinder (http://zoneminder.com)
        Wink Hub (rooted)
        Wink Monitoring
    Persistence
        Cosm Persistence
        db4o Persistence
        Exec Persistence
        InfluxDB Persistence
        JPA Persistence
        Logging Persistence
        MongoDB Persistence
        MQTT Persistence
        My openHAB Persistence
        MySQL Persistence
        rrd4j Persistence
        Sen.Se Persistence
    Misc
        Transformations
            XSLT
            JSON
        BritishGasHive-Using-Ruby
        Dropbox Bundle
        REST-API
        Security
        Service Discovery
        Voice Control
Samples
    Binding configurations
        Comfo Air Binding
        Nest Binding (new)
        Nest Thermostat
        Rollershutter Bindings
        Squeezebox
            Select Radio-Stations
            Use local TTS
        WAC Binding
        WebSolarLog
    Item definitions
    Sitemap definitions
        Multiple Items on one row
    Rules
        Misc. rule examples
        Alarm Clock
        Convert Farenheit to Celcius
        Taking Rules to New Heights
        Reusable Rules via Functions
        Combining different Items
    Items, Rules and more Examples of a SmartHome
    REST Examples
    Tips and Tricks
        Google Map
    Scripts
    Syntax highlighting for external editors
    Update-Scripts
    Controlling openHAB with Android
    Usecase examples
    B-Control Manager
    Spell checking for foreign languages
Getting it installed took a few minutes. Getting it to do something seems impossible.
Maybe if there were instructions with explanations on how to do a few things with ntp,system info, temperature, etc. Stuff that doesn't require specific hardware. Then do some scripts/rules/etc with them, that might be useful.
I toyed around with it a bit more and got it to kinda work. Its somewhat buggy and very hackish in what it supports. Not only that but getting it to do anything is a bear because the documentation is so bad.  I decided to stick with CQC for the moment. CQC supports more commercial products and documentation is light-years better.
FWIW, I notice on the mysensors forum that https://domoticz.com/ seems preferred over OpenHAB by a fair number of users.  I haven't tried it, but what I like about it is that it automatically graphs everything by default.  That stands in contrast with a number of HA software, like HomeSeer, which have no native graphing at all.
Yup; OpenHab can be a bit complex.  That said here only did play with the HAI stuff and it worked fine for me in Linux.
It is opensource and supported by a new community forum.
Because it is free; you do sometimes or not get very granular documentation.
That is the way it is with community open source software.
The authors of the plugins mostly are in to it for their own personal automation and share their methdologies or means of use of OpenHab.
Some do share more than others.
Guess here the differences are that I have been using Homeseer / Leviton HAI OPII now for many years and am a happy camper.
I am not looking to change or start all over these days with automation.  What I use or have just works me.
Because of this though I can tinker with new stuff and do.
It doesn't ever ding what is already working for me and I have no dependencies on anything new that I try.
I am very interested though in the approach and use of a variety of automation software and hardware and do try anything.
If the technology fits in to my realm then I integrate it to what I have and I have not had any issues doing this to date.
@bbrendon - whatever it is you decide to use is up to you.  You mentioned utilizing CQC.
Right here present almost every day on Cocoontech you have the author of said automation software.
Take advantage of that and go only forward now in your automation endeavor.
