So all of the sudden (meaning no changes or anything) I noticed the audible exit beep stopped working on all consoles. I checked all settings (even reset them) and also power cycled the panel and no luck. So I tried adding a simple automation block when a zone is violated to beep. No matter what I try - exit delay, automation block logic, chime, etc, none of the consoles will beep anymore. If I disconnect and reconnect a console it does its startup beep (same as when panel is power cycled) so I know the physical beeper is still working. I'm at a loss - any idea what it could be or what I can try?
