Hypothetically, let's say that I have a four zone irrigation system that I want to control from two different controllers (maybe a Rain8 and a Hunter Pro-C contoller). It's an either or situation. Either the Rain8 is controlling all four zones or the Pro-C is controlling all four zones. No other possibilities. Both controllers are powered by the same 24Vac power supply, and it has plenty of power to do the job. I can use a 4PDT relay to switch between controllers. A lead from each of the four zone valves connects to the "common" terminal for each of the four poles on the relay, e.g., zone one valve connects to pole one common, zone two valve connects to zone two common. The four zone valve outputs from the Rain8 are connected to the four N/C terminals on the relay. The four zone valve outputs on the Pro-C are connected to the N/O terminals on the relay. The coil side of the relay is controlled by a simple SPST toggle switch that provides 24Vac (from the same power supply) to the relay coil when the toggle switch is closed. So, when the toggle switch is closed, the coil is energized, the relay contacts are closed, and the four zone valves are under the control of the Rain8. When the toggle switch is open, the coil is not energized, the relay contacts are open, and the four zone valves are controlled by the Pro-C.
My question...does the 24Vac common wire from the controllers to zone valves need to be switched by a relay also, or can I simply connect the commons from both controllers to the common going to the valves, and leave it that way regardless of which controller is "on"? Note that both controllers will be powered up at all times.
Ira
Ira
