Converting X10 to IR
compuguru
Where should I get 3 IR emitters (Preferrably Blinking) from? Also, just to confrim, I can cut the cables apart and add Cat5 in between to extend the length of the cable going to the emitter right?
Guy Lavoie
Yes, you can lengthen cables with CAT5 without problem.
For your 3 emitter question: you could probably power all 3 directly with the Ocelot (as Electron seems to be doing). There just might be a bit less power available to each one so you should test each device you want to control with a single emitter connected to the Ocelot first, and then with the multiple emitters to see if that makes a difference.
As for actually buying the emitters, just hop over to an online store and look them up. Here is what I found at automatedoutlet.com
http://www.automatedoutlet.com/product.php...&cat=140&page=1
