BraveSirRobbin
Moderator
Looks like Las Vegas has some. PM me if you want one.electron said:Looks like RS doesn't have them in stock anymore in my area, hopefully they still have them in other stores.
Well, you have a good point, but a lot depends on your particular situation. For instance what if you don't want a dedicated machine with a video grabber card. Or what if there is no way you can get coax/cat5e cables to your PC from the camera's location.markthomas said:Personally, I don't see the appeal of IP cameras.
Wouldn't it be better to get the best possible image quality and do IP conversion with a separate device? Especially if you're talking about more than one camera, where it would likely be more economical as well as better quality.
I think that the allure of an IP camera is that you can avoid NTSC altogether. You are no longer stuck with 1930's resolution. Many IP cameras do 640x480 resolution, which is too high for NTSC. As sensors get larger/cheaper, you will either have to go to IP or DVI.markthomas said:Wouldn't it be better to get the best possible image quality and do IP conversion with a separate device?
Just so nobody gets confused, the $226 computer has no slots, so this idea won't fly with that machine. But the concept is still valid.markthomas said:But why wouldn't you want a dedicated machine if it was cost effective? I see the thread for a $226 PC; just add a capture card, Linux, and ZoneMinder, and you've got a rock-solid IP server that can run rings around dedicated hardware in terms of features.
It has USB slots for an add on TV tuner card. This is what I use for my video server.WayneW said:Just so nobody gets confused, the $226 computer has no slots, so this idea won't fly with that machine. But the concept is still valid.markthomas said:But why wouldn't you want a dedicated machine if it was cost effective? I see the thread for a $226 PC; just add a capture card, Linux, and ZoneMinder, and you've got a rock-solid IP server that can run rings around dedicated hardware in terms of features.
