Neurorad
I have a cordless phone, hanging on a wall. Uses a 'wall-wart' transformer, from 110V. Brick says 9V (don't recall amps, will check).
Can I run the power supply through the wall, from the closet? Do I use a power distribution module for this? Seems like all are 12V (at least from Leviton).
Options:
1. Move the 110V outlet next to the phone. Wall wart still visible. Currently at floor level, a couple feet away.
2. Put the transformer behind the drywall (open unfinished space behind, no big deal). No outlet currently nearby in the mechanical room - entails draping an extension cord across the mechanical room.
3. Home-run the 9V power supply, and possibly add a power distribution module to an enclosure. What size wire for this? How is the wire passed through the wall? I don't recall ever seeing a keystone for this. Would a mini-coax double for power?
Thanks.
Edit - after more searching, it seems a recessed bulk cable single gang "nose" wall plate could easily pass the power supply and data cables, possibly covered by the telephone unit.
Edit #2 - I would only need a distribution module if I want to get rid of many 9VDC wall warts.
Thanks for helping this noob.
Options:
Thanks.
