Does the DirectTV2PC software give you the functions you want?
http://www.directv.com/DTVAPP/global/conte...ssetId=P4920044
Using an HTPC to interface between the DVR and TV?
- Stream recorded HD programming in full resolution from your DIRECTV Plus® HD DVR to your PC.
- Watch shows on your PC while live or recorded programming is being watched on your TV.
- Enjoy the same DIRECTV screen interface.
I was not aware of this program, Nice!
Until......
I just downloaded and installed it, and it runs the system check to see if the computer can handle the playback. My computer failed, and will not let you even go any further to check it out.
The CPS specs the require are:
Pentium 4 541 3.2 GHz, Pentium D 840 3.2 GHz, Pentium D 930 3.0 GHz, 935 3.2GHz or 940 3.2 GHz, Core Duo T2400 1.83 GHz, Pentium M 755 2.0 GHz, Core 2 Duo E4300 1.8 GHz, or T5600 1.83 GHz
I am running a Pentium Dual Core 2.8Ghz CPU, and it says I need to upgrade, yet a dual core 1.8 Ghz, mentioned above, seems to be good enough!
Next, it says my GFX card is not good enough....
They require:
nVidia
GeForce 7800 GTX 512, GeForce 7900 GX2, GeForce 7900
GTX, GeForce 7950 GX2, GeForce 8400 series, GeForce 8500 series, GeForce
8600 series, GeForce 8800 series
I am running a GeForce 7900 (512 megs of ram on board), just not the "GTX", and it says I need to upgrade!
It has been quite a long time since I tried to run something and I do not have a "good enough" computer for it hahah!
