So basically I met with the Control 4 integrator yesterday again, for like the 3rd time, and he gave me a better picture after speaking with him and you guys on the thread to get a good solution.
To start he wants to use the Video Storm matrix switch w/ just straight component cable out to every TV location. He thinks this will be a cheaper solution than doing all cat5e w/ baluns. Here is what he was proposing for the a/v wiring for TV locations:
TV's w/ Surround + Local Source Options: 3 component + l/r, 5 Cat5e, 2 Cat6, and 2 RG6QS
* He said if we do it this way, there is the option later to do HDMI balun, use 1 of the Cat5e for IR, and also have a local source
TV's with TV speaker: 3 component + l/r, 3 Cat5e, 1 Cat6 and 2 RG6QS
* These are for TV's that might go in the kitchen or other areas where I'd just have a TV with no receiver and no local source, but with this setup he said we could do a local source and/or switch to HDMI balun later
Everything on the 1st level will be run by the Central Rack, so all the components will be there (receivers, shared sources, etc) then the future Theater Room is where the Central Rack will be, so everything will basically be local to that room. The 2 bedrooms upstairs that will be unoccupied with have a setup where to start it can be a Local Rack (its own reciever, sources), but he said we can wire it in a way, by looping some wires so that we could have the receiver int he central rack later and/or just have the shared sources as an input to the local reciever. He said what we can do with the wires is make them long enough and loop them in certain positions, so that way we can then go and and 'cut' them to run components from the Central Rack, pretty kewl.
He's cool, he actually agreed to do the wiring plan, equipment/cable list and documentation for me, at just his consulting fee. He said he normally won't do that but he understand that I'm on a budget, and his inital cost for them to do the PRE-WIRE just for materials was $4300!!! and I can get it all online for like $1000-1500 tops I believe. Buying all bulk cable.
Speaking of that, what brands, online sites do u recommend for getting cabling? I'm going to need bulk Cat 5e, Cat6, Mini-Coax, etc. I was thinking that I could get some of the combined cable (2 Cat5e, 2 RG6QS) as well as straight network cable where needed. The combined cable is more expensive tho.
Thanks for everything guys! I'm almost there!!! Actually you can follow my progress on completing my home I'm supposed to close on Wed at this blog:
http://436staffordstreet.tumblr.com/
