Just wondering how many cocooners have door strikes installed on their homes. What areas are you using them on (exterior/interior)? What brand/model? Likes/dislikes? Finally, if you have any pictures of them installed... please post them.
The only dislike is the amount of material you need to remove in order to install the strike.
I use a Von Duprin strike and an Elk M1 to manage access control.
A hidden lock box allows access to the house in the event of a power failure or strike malfunction. I integrated the strike into the backup power for the Elk, so even with the power out, I still get about a day of operation.
Rutherford 6 or 7 series:
http://www.rutherfordcontrols.com/products...x.asp?pathID=29
HES 5000 Series
http://www.hesinnovations.com/en/site/hesi...roductId=148865
Stay away from Trine or any other strike that doesn't cost much. IMHO. You get what you pay for.
I'm always interested in hearing about fail-safe's in case of total failure. Does your lockbox simply provide a key to open another exterior door?
When the strike fails securely, the door reverts back to operate just like a normal door. The key unlocks the door and you turn the handle to enter.
Could you explain this in more detail? My understanding of Fail Secure is that the door remains locked when power is absent. So even if you unlock it with a key, wouldn't the door strike prevent the door from opening?
Most standard strikes will not operate when there is a load on them.
Securitron makes a strike called the "unlatch" which the deadlatch portion of the strike drops in and then the strike pushes the deadlatch and the latch into the door to allow the door to open.
http://www.securitron.com/en/site/securitr...UnLatch-Strike/
