I have a number of architectural 0-10v LED fixtures in my new home. This probably isn't the way to go here, but I control them via Lutron Homeworks. Homeworks can be configured to drive DMX loads with a protocol converter. I have about 20 LED zones that I run with DMX (gives really great control). Once you have DMX as a protocol, there is a simple box to convert DMX into switched relay and 0-10v, so I use those (as a bonus, it's DIN rail mounted). If I was going to do it again, I would have pulled out the 0-10V dimmer packs in the fixtures and just replaced them with a DMX PWM controller. The 0-10V fixtures seem to only dim down to about 10% whereas DMX PWM controllers can go down to less than 1%.
