OK. While running some low voltage cables, I took out a couple of line voltage wires. In haste, I pulled through new wires and took apart a 3 gang switch box. Unfortunately, I did not make note of all the wire connections. I am almost certain it is a 2 circuit box with one switch and two 3 way switches. So I can all the neutrals be tied off together. I believe this is how it was originally. It would be 6 neutrals nutted together.
Mike
Mike
