2blackbelt
Hi everyone,
Newbie here trying to wire a Elk M1G with 16 Smokes along with approximately 60 zones, 4-5 Temp Sensors and a Elk WSV (Water Shutoff Valve). Because of the power requirements I am using a Elk P412 four amp power supply. The smokes are the System Sensor 4WTA-B. All smokes are homerunned into the panel. Using a RSSMOD and EOL Resistor so that I would know which smoke oView attachment 3626riginated the alarm while all smokes alarm. Since the Temps require a zone between 1-16, I was looking at purchasing two Elk M1XOVR for the smokes to wire into. Run into a brain fart and cannot figure this out. Any help would be appreciated. Attached is a chart showing the RSS Mod as if it were connect direct to the M1G using zones 1-16. Now that I'm using the additional power supply and possible M1XOVR, I need some help. Here is the link the diagram. I've also got a PD9HC (Power Distribution Module) and a P624 (Power Supply and battery charger).
Your help is appreciated.
