I am going to have an Elk panel and hook this to a Homelogic system. I want to be able to program the elk with software over my LAN. The problem I see is that Homelogic ties into the Elk from the main serial port and so does the module to connect Elk into the LAN. Is there away around the problem or do you have to hook up the internet module to program then disconnect to hook back up to the Homelogic system.
Chad
Chad
