Elk Keypad
nov0798
I have an M1KP keypad, that I have been using for some time. Today, I added 2 M1KP2's. I set the keypads to addresses 1, 2, 3. The keypad that was originally 1, is still number 1. For some reason, I cannot get it to work now. The keypad states that it has lost comm. I brought the keypad back to its original spot and it works fine. I tested the wiring for the new keypad, and it is fine. Any ideas why the keypad does not work now? Also, each keypad plugs into an M1DBH. Even when I bypass the wiring to the keypad and go directly to the DBH, it still doesnt work. Any ideas?
Have you gone thru and enroll these two new keypads?
OK, Nevermind, I figured it out. I basically removed all keypads from RP, did a hard reboot, with just one keypad, then went and enrolled the others. Ill all seems to work now.
yes!
RP says the unit is missing or not working
Yes, of course: every keypad comes from the factory as keypad#1.
And at first you had to set the keypad-number you wish:
(see page 2 of the instruction of your keypad)
First connect it to the RS485 bus.
Because now it has juice, the display is lighted.
Press the "*" key for 10 seconds or so, until the display shows
"Exit when done. F1 Set Addr"
Now press <F1> and enter the sesired KP-Addr. (Between 1 and 16)
This you cannot with the ELK-RP-Programm. only direct at the keypad.
The KP-Addr-Setup is the first step.
After <Exit> the ELK-System is knowing the different KPs.
And now it becomes possible to enroll the new items in a second step.
Best with the ELK-RP-programm.
