Not true. Check the second line of the specs of the Elk-9100:Steve said:Unfortunately the Elk-9100 is X10 only. In fact I do not know of *any* non x10 220v control. Martin - you know of a 220v UPB controller?
FEATURES / SPECIFICATIONS:
• Controlled Remotely from X-10 Power Line Carrier Commands.
• Optional Dry Contact Closure Activation.
But probably at least $20 per month cheaper to run anyway.Spanky said:If you have a gas hot water heater, you are out of luck. Not controllable!
??? There is no electricity on a gas water heater. My point was a gas water heater without a setback controller is as cheap to run as an electric one with a setback controller.electron said:shutting the electricity down to a gas hot water heater wouldn't stop it from running, or are you worried about the pilot light?
