Just in the middle of bench testing my system and since this is my first major security system install, I'm learning as I move along ... the one thing I haven't completely figured out yet is 'areas'
The way I understand areas, they are a way to set up sub systems on the same control ... the easiest way for me to understand it would be to think of them as departments in a company ... I'm assuming you assign different zones to different areas and I understand that Area 1 can be used as a common area (such as a lobby for a company that is shared by many departments) ... is this about right?
If so, are there any natural uses for areas in a realatively small (3 bedroom) private home? Or should I just stick to a one area system? I would like to have the opportunity to set up limited access to parts of the property such as the backyard for the pool guy etc. without giving access to the home. Are areas the right way to do this? Also, I'd like to set up a motion detector perimeter on the property that doesn't trigger a burglar alarm, but rather just a verbal warning ... how should I best design this?
Lastly, are there any good resources out there for designing alarm systems, especially using the M1G? It seems that there are such a huge array of features and possibilities ... I could use some experienced minds to help harness the full potential.
Any thoughts would be appreciated.
