Wow. This is why I am going to just bail on the Elk. Too many long standing bugs that never get fixed, too many missing features, too much bad documentation, too many functions that just don't work well or don't work at all.DELInstallations said:Your overall length statement is NOT true. It splits the 485 bus into 4 managed branches. It does not regenerate or repeat the data. Look at the note on the second page of the installation document. Right in the diagram of the topology and connections, 4K total length, which I've confirmed with Elk before (I had a project that required an exceptionally long pull between buildings).
Your information about the M1, voltages it operates on and functionality and design criteria is inherently flawed. The main panel does a LBC at 10.2VDC, however the bus devices will start to reboot and lose connectivity far before that value. Once they start to dip below 12V, they start misbehaving, and right around 11.5VDC (memory) is when the reboots actually start occuring with bus devices.
The design criteria for the M1 bus devices should be to maintain 12VDC (or as close to) at the end of the run for VD calculations.
Quote from the M1DBHR manual "Like the Main M1 Bus, the Maximum wire length of any of the 4 branches on the M1DBHR is 4000ft." As stated this would mean that you could have up to 4 (or 8 with two M1DBHR) runs of up to 4000' each. If this is not the case then the documentation should state that the total length of all runs can not exceed 4000' total.
If the M1 cuts out on battery power at 10.2V but the M1 peripherals cut out at higher voltages that would make the M1 a useless system on battery power. From what I have seen so far with the Elk that would not surprise me too much. But I do think you are incorrect on this. The manual for the input expander says it will operate form 9-14 VDC. Other devices I just checked don't state a minimum voltage just 12V or 13.8V operating voltage. The peripherals would need to operate at least down to 10.2V, and since the output voltage from the M1 is actually 0.5V less than battery voltage this would be 9.7V to the peripherals at the point that the M1 shuts down. If any of the devices reboot at your 11.5V you better install charge pumps for their power. This is one big reason that having a majority of your capabilities in lots of "expandable" peripherals is not such a great thing. More points of failure, more sources of problems, more wires, more installation space required, etc.
I've wasted too much time here and on this system already I'm moving on.
"The design criteria for the M1 bus devices should be to maintain 12VDC (or as close to) at the end of the run for VD calculations." - Thus my initial point that voltage drop of the power is much more limiting of the wire length than the RS-485 bus.
