davetoolin
Great site, reading the posts here convinced me to go for the Elk M1 Gold setup.
Most everything is good, but have a problem. I can access my home system remotely using the Java interface. But after a while it stops working.
To get it working again, I need to connect via Elk-RP and reboot the M1XEP, then it works fine for a couple of days. After that it drops out.
Call Alarm Relay to put the system in test, connect via RP Reboot and it is up again.
Very strange.
PS. The main reason for using this interface is to check the temperature probe I installed before leaving. It's finally cold in the NE and would like to easily keep an eye on the temp. side question is there a way to write a rule to email me the current temperature every night at 3AM??
System info M1 Golg, M1XEP, connected to a linksys router on Comcast.
Dave
Very strange.
Dave
