Hello,
Tried installing this tonight and have had no luck. Initially tried it with two keypads and the serial expander device but nothing had any power. Then scaled back and just tried to get one keypad to go, again, no luck. I've terminated J2 on the M1DBH with the dummy plug and also J3 on the M1 Control panel with a short out pin. I'm pretty confident that my T568A jack is good. When I start up the M1 the power light comes on but I don't get a flashing green status light. Also, I checked the voltage across +VKP and NEG and it is only showing .03V. Not sure if there is constant voltage from these terminals or not. My next step will be to try and hook up the keypad directly to the M1 panel and forget the M1DBH. It was hooked up this way earlier and it worked fine but I want to hookup more devices on the data bus so I thought this device would be the way to go. Can anyone offer any suggestions or help. Thank you.
