BraveSirRobbin
Moderator
I recently installed an Elk Navigator touch screen. It's a nice unit but one glaring problem is the menu for the lighting controls. It's bad enough it is several clicks away from the main screen, but I noticed that ALL of the X-10 devices are displayed as line items, even the ones I did not select to "view" (the ones not selected are just grayed out and not eliminated).
This is a huge WAF problem for me (only reason I bought this thing) because I use the first part of house code A, then switch to C. You have to scroll through the lower half of the A house code, then all of the B house code just viewing 'grayed' out selections, before getting to the desired C house code menu.
What exacerbates this problem is the slide menu select on the right isn't all that great for navigation.
Is there any way to completely eliminate the unused lighting from being viewed? It takes so long to select a light that she will just walk over and use the switch in the other room (sacrilege
Of course, I may be doing something wrong in the setup, but I did NOT check the view checkbox in the Elk Setup Software (for the lighting house/unit codes not being used) and then did a 'sync' of the Navigator. I will explore the 'tasks' options, but just wondered if this could be fixed before trying to go an alternate route.
