IVB
I finally plugged the Elk RJ31X into the telco line. Tonight I added some Communicator info so I could try contacting NextAlarm, incl my first entries in the "Telephones" section of ElkRP. As soon as I uploaded it, the Elk reports "Phone Fault". I know the RJ31X is working fine as it cuts off my house phone and takes control. Hence, I need to leave it off so I can use the phones.
Any idea what could cause this? The one thought I did have is that the tip & ring wires are unlabeled from the telco, so I took a guess, figured I had a 50-50 shot of being right. The phones & DSL work fine, so I presumed that I had guessed correctly.
I'll try switching them, but I can't come up with anything else to look at. Any ideas as to what other things I wondering if there's anything else I should check on?
