Not sure if I am tired or what, but the M1XEP connects to the main serial port, not the serial expanders.Mike said:I that is the normal way to connect it to HS (I don't have HS, but I do have the ethernet module for the M1G and am very happy I bought it.)
The other thing to consider is what you will integrate. If you use the ethernet module you will need a serial expander, that will add another $45 or so (I thought $75 but the main serial expander on the EZ8 is around $45 the subsequent ones are close to $75. That just brings the number down a bit if it helps your decision.
Where are you getting it and what are you paying? The M1Gold is a lot smarter choice IMO especially for all the features you are wanting.hgupta1 said:Money is tight right now, so I will have to go with the EZ8 for now.
If anyone wants to upgrade from the EZ8 to the M1G, I'll be happy to buy their old board from them.
That is the fancy term for "playing and learning and not disturbing the WAF". I haven't heard of anybody ever getting a defective unit, so it is more user education than anything.hgupta1 said:Also, many of you and the manual mentioned "bench testing" the system. What does this entail?
I believe that Electron said that he added that request into the soon-to-be-released, err, upcoming, err, sometime between now and ???, version of CocoonTech. (Just kidding E. Put your vodoo doll and pins away!)change the minimum word length that a search
