apostolakisl
I think what both of you are talking about are just plain equipment failures, not failure as a result of some event outside of spec'd operating parameters. In the normal course of operation, everything has a failure rate. Manufacturers know their product's failure rates and they know the cost to make it lower or how much they would save if they let it be higher. They choose the failure rate to maximize profit by considering the actual cost of production and what a failure does to their reputation and future sales. As a consumer, I think you would be beating your head against a wall trying to protect yourself from these failures. Buy stuff that is made by reputable companies and use it within specs and then move on. Personally, I don't worry about putting 110 vac 10 amps on my Elk relays because Elk has a good reputation.
Focussing my efforts on protecting my equipment from over-spec events is where I think my concerns should be. Putting an extra set of relays on a sprinkler system line is not lightening protection, so I don't do it. I have had in the back of my mind that a lightening strike does put my Elk at risk becuase of my sprinkler lines. Until I just came across that rf relay, I had never seen a solution that wasn't extremely costly or had so little chance of success that it was a waste of time. If those rf relays work, I will probably buy a couple more and move my sprinklers to them thus absolutely isolating the Elk from the yard, and at a pretty reasonable price.
