MichaelMcA
I am new a new Elk M1 Gold owner and have not been able to get the touchscreen to talk to the main panel. When I try to connect the touchscreen to the main panel, a small window opens and it loops through the following sequence:
ElkM1 Status:
Connecting In N seconds...
ElkM1 Status:
Connecting
ElkM1 Status:
Disconnected
(where N counts down from 10 to 1).
This happens over and over.
My system:
ELK-M1GOLD Main Panel
ELK-M1XEP Ethernet Interface
ELK-M1KPB Keypad
ELK-TS071 Touchscreen
The system is brand new and spread out over my workbench for setup. Initially, I used a laptop with Elk's USB-RS232 adapter to communicate & setup the main panel using ElkRP2 v2.0.8. That worked great. I then added the M1XEP module to the main panel, replacing the USB-RS232 cable with the M1EXP's serial cable to the main panel. Using the laptop, I configured the M1EXP to use a static IP address. Running ElkRP2 on the laptop, it is able to communicate with the main panel using the "network" communication setting. Also using ElkPR2, I enabled the non-secure port (2101), and enabled Serial Port Transmit of everything (Event Log, Task Changes, Zone Changes, Lighting Changes, Output Changes and Keyad keys). The baud rate is 115,200.
To confirm M1EXP/M1Gold connectivity, I close ElkRP2 on the laptop, open a web brower, and point the browser to the M1EXP's static address. The Java keypad application starts and I can communicate with the main panel. So I close that, and try to communicate w/ the touscreen. From the TS071, I start ElkRM and enter the M1EXP's static address and the non-secure port (2101). I have tried using the Installer Code & user codes. I every case, it does the above sequence ending immediately in "disconnected".
I know the touchscreen is connected to the network w/ proper gateway, mask, etc because I can use the touchscreen's web browser, and, after setting the Zip Code and clicking "weather", ElkRM displays correct weather info (yes, MORE snow). Incidentially, I downloaded a trial version of ElkRMS onto the laptop, and the exact same thing happens.
Any ideas on a setting that I am missing?
Some versions from the laptop's RP2 help screen:
Main Program Version 2.0.8
M1G Control Version 5.0.8.0
M1 Control Version 5.0.8.0
EZ8 Control Version 5.0.8.0
ElkComm Version 2, 0, 0, 0
ConvertDB Version 1.4.8.0
ElkSafe Version 1.1.8.0
ErrorDlg Version 1.2.8.0
On the touchscreen, ElkRMS ver. 2.0.10
ElkM1 Status:
ElkM1 Status:
Connecting
ElkM1 Status:
Disconnected
My system:
ELK-M1KPB Keypad
