I recently purchased and installed three HAI Omnistat2 RC-1000 thermostats. Regarding connection to the Elk, I can get each one to individually connect thru the XSP correctly except for the fact they will only work at 300 baud.
When I connect two thermostats they both report status through the Elk keypad correctly. They still only connect at 300 baud.
My problem is when I connect all three together. Only the first two thermostats report status correctly thru the Elk keypad. The third reports 'Not Enabled'. Each has a unique address (1,2,3) and speed is set to 300 baud.
Could it be inadequate power when all three are connected?
Thanks for the help!
Scott.
Scott.
