This is a great thread - it's the subject of some struggle I've had over the past 8 years in this house.
Here's a pic of my equipment room (upstairs) and current setup (a little messy as I just installed uverse and consolidated 4x8 port switches into one large 24port switch)
I had the luxury of building the house, so I could spec exactly what I wanted - though I was naive on the ventilation side of things. It has an A/C vent on the upstairs HVAC circuit.
The room has 2 PCs (1 for automation, 1 for media center, both overkill 4-core) and a large NAS drive (9TB), along with 3 receivers, one theater amp, a wholehouse audio amp, various other distribution/interface components (A/V, IR, Ethernet, etc), an ElkM1, A/V sources (ATV, DVD). The ELK turns off the HVAC vent with a damper when the system is heating.
Day one, there was a heat problem because there was no ventilation (duh). I've tried two ventilation systems.
1. A 75K BTU room A/C unit venting to attic (worked great, but used a ton of power)
2. A variable speed furnace blower that is on all the time, but slows when the A/C unit is not on. Mated with a 200CFM exhaust at the top most corner of the room, opposite the AC vent, dumping into the attic. The A/C vent is 8" (originally a 4" vent). I also have a large box fan running at low speed routing air across the equipment rack to aid with convection. This works OK, but temps can still spike in the summer.
Some temp trends this week:
Some things I'm going to do in the future:
- I need to integrate the exhaust back into the main system - but I've lacked the motivation because I still think dumping to the attic is more economical.
- Consolidate the media center PC and the automation center PC with a 35W i3 core, switch to an SSD for the main drive, consolidate all the extraneous drives to one 2TB unit. (lots of $ and fear of windows7 running my automation)
- (out there) If I ever get to installing a solar heater for hot water or the pool, I may circulate first through a heat exchanger in the equipment room. This waste heat is useful if I could harness it.
Ultimately, the PCs are the issue. They draw at least 400w between the two of them. That is where I would suggest focusing your time - energy efficiency.
