TJFitz1980
I am mounting a flat panel television in my bed room. The thing is that the other side of the wall is our closet so, here is what I am after. I am going to place all my components (satellite receiver and DVD player) inside the closet so that only the tv will show. I am having an electrician come over and put a 4-way 110 outlet in the upper part of the closet directly behind where the television will be located and the components will all be on the upper self.
I am planning on cutting around a 3" hole straight threw both bedroom side and closet side of the wall behind where the tv will be mounted. I am looking for some type of tube with beauty rings that will snap together to fit into the hole. The only thing I can think of to compare it to is the plastic rings you see on computer desks for pulling wires through. Does anyone have an idea where or if I can find something along those lines?
My second question is...since all my components will be inside the closet behind a wall what kind of item do I use to be able to use my remotes? Is there a product which will allow me to use my satellite remote instead of getting a universal remote?
Thank you for any help you will be able to provide,
-Travis
-Travis
