PaulD
Help me settle an argument I am having with myself. I am using Form C relays to switch 24VAC power to a load using the C (common) and NO terminals on the relay. Trying to determine is there is any good reason to hook the 24VAC to the NO terminal and the load to the C...or vise versa. I know either way will work but I am curious if there is any standard practice or good reason to do it one way vs the other. The main reason I can think of to apply the 24VAC power to the NO terminal is that if I apply the power to the C terminal, then the NC terminal is also hot when the relay is not activated.
