Functional difference between ELK keypads?
Sendero
Besides the new flush keypad having two fewer function keys, and it not having space enough for a card reader in it, are there any other difference between the two? I order a kit with the newer style keypad but received the old one. I like the look of the new ones better but if there are compelling functional reasons to keep the older one then I may do that.
forgets
well, the big difference is the new keypad, the kp2 doesn't have a temp sensor built in, which the kp1 does.... that was a big sticking point for a lot of people.. other than that, you can put a prox reader on the kp2, it just has to be mounted externally per the manual, not in the same housing as you can do with the kp1...
hope that helps.. ! :D
