Mike,
To confirm, the only way to use a X10 remote with Insteon is with a PC & software (CQC, Homeseer, etc)?
Rich
No, Insteon switches can physically be assigned X10 addresses. However, depending on how reliable X10 is in your house, and the complexity of what you want to do with your X10 remotes, sometimes a PC works better.
Mike,
OK, so you can either use the Insteon protocol or X10 protocol per Insteon device, its not a combo protocol of both (the device set as an X10 can also take Insteon commands).
Choice A: Set Insteon devices to X10 protocol, use either a Signal linc / Access point, or X10 transmitter, X10 remote
Choice B: Set Insteon devices to Insteon protocol, use Signal linc / Access point, X10 Remote + PC with Software to translate the X10 to Insteon commands.
In my case, the more Insteon switches I added, the weaker my X10 signal was getting. There was 1 or 2 switches I couldn't reach once I had all of my Insteon switches installed. Instead of troubleshooting my X10 issues, I decided use my PC to translate.
Im a little confused, can the Insteon system respond to X10 commands in the Insteon protocol without actually using the X10 protocol? Is your home setup using the X10 or Insteon protocol?
Also, I want to trigger PLC groups (hit a remote button, my driveway light goes on along with 8 KeypadLinc buttons) - I couldn't do that reliably without a PC.
Hrmm, I admit I am a complete newb (but I bet thats obvious). Can you program the PC so that when button 6 is pressed on any remote in the house, that it translate that into turn on Group 8 (group 8 = driveway & keylink 1)?
