I have a Jandy pool/spa system that I will be interfacing to my OmniPro.  I'm determined to be able to utilize the temperatures that are in the Jandy system from within the OmniPro one way or another.  I've seen the instructions on using custom messages, but that is way too limited.  You would need to have a receive message for every possible temperature combination, which is not feasible.
The Jandy system has temperatures for the following: Spa Temp (and setpoint), Pool Temp (and setpoint), Solar Temp (and setpoint) and Air Temp. I'm looking for a way that I can somehow emulate the data being fed to the OmniPro (like it was being driven from a thermostat) so I can have these items come up on my temperature screens. The serial and TCPIP protocols only let you read temps and set high/low points, they don't allow you to set a current temperature for any sensor or thermostat.
Does anyone have any ideas on how to accomplish this? I can program a serial gateway between the OmniPro and the Jandy system (via a micro) or I can write a server based app that talks to the Jandy system via serial and the OmniPro via TCPIP. I just need a method to get the external data into the OmniPro. Ideas anyone??
PS: I'm finding the whole serial interfacing in the HAI world incredibly limiting.
