Giving Up On Insteon
Herdfan said:
While I am not quite up to Mike's switch count, I am getting closer. At lat count I had 81 Insteon Devices with 950+ links.
I may have twice as many devicess as you but you have me beat by a mile as far as Link count goes. Now that my KeypadLinc problem is fixed and PowerHome is doing my X-10 to Insteon translation (until RoZetta is ready), I'm not as stressed about Insteon as I was the other day. I probably won't go changing horses now unless something else goes drastically wrong.
bfisher said:
After using it for a couple days, you hardly notice it anymore. However, for guests (and in-laws), it is a little confusing.
I have to disagree with this (though it's a preference thing). We've had our UPB stuff installed for over a month and it still bugs us.
Comparing the delay between Insteon and Z-Wave which is slower? What about comparing advantages and disadvantages between Insteon and Z-Wave. Is it true that metallic gang boxes should not be used with a wireless protocol like Z-Wave?
Thank you.
Thank you.
I'm not sure what kind of delay you are talking about here. UPB has a delay by design while it tries to figure out if you are going to do a single tap or double tap on the switch. Insteon does not have this delay and is "instant" unless you have a slow start ramp rate set in the switch or if there is a problem with transmission (usually due to not using RF SignaLincs) that causes the switch to react to the second or third retransmission rather than the first. This can cause a slight delay but only for remote transmission, never local control.
I don't know about Z-Wave.
Thank you.
RonX,
The delay for turning on a switch it totally based on the manufacturer of the switch first, and limitations of the protocol second.
In Z-Wave, there is no required delay in turning on a light locally. As far as remote control goes, the majority of devices will turn on within a few dozen milliseconds, and with the new devices the datarate is 4x faster than that.
Chris
Well, that is what 9 KPL's will get you. Especially then 4 of them have either an all ON or all OFF button, or both. And 2 run in 8-button mode.
How big of a delay is there when turning on a light? That's one of the points I liked about Insteon - they say the delay is much shorter than x10. Is UPB quicker than x10, or about the same?
Well, two different things are at play -- the delay between pressing the wall-switch button and the light coming on (between .25 and .40 seconds) and the delay in executing a command sent to it over the powerline. The former is what bugged me at first, but as others have said, we all got over it and don't notice iit anymore (took about 3 weeks). The later is like .2 seconds -- about 10x faster than X10 response time.
Lastly, what advantages will I see if I move from x10 to UPB if x10 has been reliable to me so far (since I purchase a dryer outlet amplifier/bridge, x10 has been like 99% reliable).? It seems like you can find some good quality x10 switches (Switchlink?). What are the disadvantages right now of just going all x10?
I had the Leviton X10 switches (the ones with real rockers (press top for on/bright, button for off/dim) and I loved them. I didn't like most other X10 wall switches and I suppose if X10 was still working as well as it had been, I'd probably not have upgraded (changing out 74 switches isn't cheap or a quick job).
Things I always wanted from X10 but didn't have were two way comms (so switches would send status when they changed and/or could be polled), faster response time, scene support (the Levitons had them, but not all switches where leviton and the scene ability was limited) and a nearly 100% reliable protocol (partly this is elelctrically, partly it plays into the 2-way stuff).
Even wanting all that, I didn't really even think about upgrading because of the expense. As much as it was a pain though, now that I have UPB, I'm almost glad things worked out the way they did. Scene control is easy and most devices support 16 scenes (from a pool of 254 scenes -- UPB calls scenes "links" for some odd-ball reason) and the two way stuff lets me do some fairly nifty things and have all my other HA equipment accurately track all device states.
Not sure if that helps, but that's what I noticed.
Gerry
RonX asked:
I have this same question. My house is a little over 30 years old so all my boxes are metal. I have X-10, Insteon and UPB, so far, so I thought why not try Z-wave too.
Anyone have insight on metal boxes?
Haven't tried it but I have heard that the transmitter/receiver on the zwave switches are in the paddle area of the switch so it shouldn't matter. That being said, I would still stay away from metal boxes with zwave. What if the device the switch is talking to is behind the box?
This is one of the reasons why they say the switch should be installed at the location it is to be used at before configuring it. And if it should move you need to remove it from the network and rejoin in the new location.
I know ThePod uses Z-Wave here in Chicago and we have all metal boxes and he has not complained yet.
Hmmmmm, lots of Smarthome and Insteon bashing going on.... Where's SmarthomeMike when you need him???
I am not bashing Smarthome and this is nothing personel with Smarthome Mike but Smarthome needs to be more proactive in resolving these issues. People are spending a lot of money and finding out that the product doesn't work the way they say.
Me too. We used some UPB switches for a few months and the local control delay is what made us rip them out. Even after a few months we still hadn't become used to this highly irritating "feature".
I could understand the switches taking the time to detect the difference between a single or double-tap on a device where they were programmed to do two different things. If they do the same action then the artificial delay is a pure nuisance.
If they solved that then I'd be seriously considering dumping our Insteon switches and replacing them with UPB ones. Well, except for the SA ones being too big for our J-boxes that is. The HAI ones I tried were smaller and fit ok, but I hated the feel of them. They felt "cheap" to touch.
What drives me crazy about Insteon is
- The PLCv2 is unbelievably dog slow and cripples PC interaction with the network
- Bugs, Bugs, Bugs!
- Things the designers forgot. (eg: you can't include an 'off' level in a scene. eg: you can't have 3 lights turn on and 1 turn off when you activate a scene - It appears you have to do things like having the scene turn it "on" to 3% dim instead of off. Not to mention the dual-linking hack to work around missing status reports, etc)
- Unfixed hardware problems that would have turned up in 3 seconds in a real world beta test before they started their mass production runs. (eg: appliancelincV2 fiasco, switchlincV2 microswitches wearing out under heavy use or in bathrooms, or the firmware turning "on" after power glitches that crash the onboard microcontroller)
- Don't get me started about the fake security system that achieves little apart from making life hard for programmers. (By fake, I mean the packets on the network are cleartext and unprotected. The PLCv2 censors the computer's view of the packets. You lose debugging ability and gain very very little, especially when there are old revisions of the PLCv2 with broken censorship handy. Or signalinc-RF's that don't implement pairing at all and will repeat with anything in range, regardless of the set button.)
I'm still waiting for switchlincv2-relay version 2.2 to ship so I can get accurate status reports from the kitchen. My wife presses both switches at the same time and causes a collision. The broken retransmit mechanism means both switches retransmit at exactly the same time and never succeed. The firmware in 2.2 switchlincV2-dimmers supposedly fixes it, but that hasn't made it to the -relay version after something like 6 months now.
The real crying shame is the extended message issue that KenM alluded to above. It's what turns link verification on a large network from an operation that should take a few minutes into an operation that takes hours. We should be able to read 14 bytes per packet instead of 1 byte per two packets and so on. Combined with the dog slow current revision of the PLCv2 and this is especially bad.
The most frustrating part is that they dont seem to test their fixes in the real world. eg: they made TWO revisions to the appliancelincV2 without testing in the environments that are known to kill them. So they committed to production runs of "fixed" products that didn't actually fix it. This is not the only case where this has happened, but it is the most graphic example.
X10 (unreliable), UPB (delays), Z-wave (closed system) and Insteon (bugs) all suck. I'm starting to like the idea of hard wired systems.
