Has anyone with the HAI Access control system used non HAI Access Control Cards/Tags? HAI says you have to use there 125khz cards but I find it hard to believe that
third party 125khz cards wouldn't work. Anyone test them?
Not likely locked to a FC, but more likely to have a parity bit and where the data string resides. Easy enough to figure out what the scenario is if you have a card.....problem is you'd need to determine the raw data.
I'd look at the card(s) personally and see what it is and contact HID....they're probably the OEM on the cards.
