HAI Dimmer Trigger
uptito
I don't know if it's possible butI thought I ask first before I waste time. So what I want to know is that can HAI dimmer be used to trigger action in OP2?
What I'm trying to accomplish is that I would like to change alarm status from night to day or bypass downstairs motion sensor when any of the bedrooms HAI 35A00-1 dimmer is turned on at night and restore it back when it's turned off. UPStart dimmer property has "Transmit Components" tab so I thought UPB dimmers can send and receive upb signals and use the signal as a trigger in PC access to perform action. Thank you
I'm an elk person, not HAI - but I know it's possible in Elk, and 99% sure it's possible in HAI. Look at rules for a trigger based on a UPB event.
Okay I followed UPStart doc but couldnt get it to work to trigger event. Obviously I'm doing something wrong. FYI, Dimmer and OP2 works fine. I can arm/disarm from PC access or keypad and also dim/turn on or off. I'm happy with it. I'd like for someone to point me in the right direction please.
You need to program it into the Omni.
e.g.
Code:
WHEN. Bedroom Light OFF
THEN Arm Night
WHEN. Bedroom Light ON
THEN Off
