Preparing to setup my HAI system. I have read the manual and looked at the quick start guide. I am confused about the proper way to wire my keypads. I will have 6 of them and they are homerun with 22/4. From what I can tell, the quick start guide indicates I should just connect all 6 of them to directly to the board. Is that the preferred setup method? I know the Elk has some kind of keypad board, in which you connect all you keypads, and then run that to the board. However, I see nothing like that for HAI. I am concerned about trying to connect 6 keypad 22 gauge wires onto a single connection point - primary concerned that they will not all make contact or that I might end up with a loose wire.. Any tips here?
Also, What gauge wire do I need to run from the transformer to the board?
Looking forward to getting this system up and running!
