That is why I keep pushing for Elk to match the HAI feature set. HAI has some things that are attractive to my situation (but may not be of value to anyone else).Mike said:You may also wish to consider if you are doing this yourself, UpstateMike. HAI never seemed to be DIY friendly (if that is what you were planning). Not sure if that has changed.
The Elk does allow for access control keypads. We have several of them. The key is for it to be Weigand compatible. Look at the Rosslare ones.-An access control keypad as an alternative to using proximity sensors.
davidl;DavidL said:The Cinemar MLHAI plugin has now been released and includes support for the HiFi HAI system. Not full support yet as the protocol has not been completely released by HAI. We also have not been able to test this as there isn't hardware available yet, but the information we have gotten from HAI is very straightforward execution so we expect good results.
www.cinemaronline.com/mlserver.mlhai.html
DavidL;DavidL said:Of course once hardware is made available, those command extensions will be tested as well, as do ALL products that Cinemar produces (and every other software hardware interface company I can think of)
The primary purpose of the plugin is to support the security panel, not the HiFi addon.
