HAI Omni help
dcrna1
Hello, I am new to the forum and need help. I have an HAI Omni pro with only one key pad in the house. My bedroom is already wired for another key pad, and I want to put one in the, but my dealer wants $450 to do it. Can I buy the key pad and install it myself, or do I need them to come out and do it? Thanks for your help!
Flushmount?
Can you cut a clean hole in the drywall?
Running the cable is the hardest part. Since it's already done...
Hooking up and addressing a second console should take less than 30 min.
4 wires at the console, 4 wires at the panel.
Power up and change the address on the new panel.
Done.
How do I change the address? The wires from the console are already run to the 2 gang wall plate in the bedroom.
Flushmount?
Done.
Installation Manual:
The console has different operating options that can be setup from the console to the user's preference. If more than one console
is being used, it is required that you give each console a different address. You can change the address of a console through the
console setup mode.
To enter the console setup mode, simultaneously press and hold the 4 and up arrow (↑) for approximately 1 second. The console
will beep 5 times and enter the setup mode. The top line of the display will indicate what you are doing, followed by the current
setting. The bottom line will show a menu of your options. To the lower right corner of the display is the direction arrow(s).
Where possible, the up (↑), down (↓), and two-headed arrow characters are shown on the console display to indicate which
arrow keys may be pressed at that time. Press the down arrow (↓) key to advance to the next item. Press the up arrow (↑) key to
go back to the previous item.
CONSOLE ADDRESS
If you are installing more than one console, each console must be set to a different address. The default address setting is (1) -
this is adequate if only one console is being used. The choices at the bottom are 1-16. When making your choice, choose an
address between 1-16, then press the # (pound) key.
EXIT SETUP MODE
To exit Setup Mode, press and hold the 4 and up arrow (↑) keys simultaneously for about 1 second. The console will return to
normal operation. You may need to press (*) to restore the display.
