Thanks in advance for any help this community can provide. I have an electric deadbolt installed at my front entry which I'd like to control via my Omni board. There are no control lines running from the bolt, so my only option is to control the power to the unit. The bolt is normally closed and draws 900mA, which is too much for either the on board outputs or my HAI relay. Thus, I'd like to configure my system so that one of the outputs, either on the Omni board or the relay, controls a supply directly powering the bolt. Perhaps a higher voltage, externally powered relay exists that could provide the simplest solution, but I am open to any and all suggestions.
