OK purplehayes is not crazy. There is a problem...
Yesterday we began receiving some calls about messed up screens... Well it appears that on some PCs the user version of PC Access 3 fails to load the text resources. I was unable to duplicate on any of my test systems, but one of our tech support guys was able to duplicate it on his system. All three versions (Dealer/User/Lumina) of PC Access use the same code to load these resources, and it works on some/most PCs. I am suspecting some slight difference in the .NET framework from system to system. Anyhow I added some additional error checking to detect and correct the problem.
The bottom line: no data is corrupted, it is merely a problem with the text displayed on the screen. It appears to only affect some PCs and only in the end user version of PC Access 3 version 3.2.0.547.
A new build of all PC Access versions has been posted. If you are experiencing this problem, please update your PC Access now.
NOTE: Some users also reported a null reference exception when starting the "bad" version. If you are seeing this error, just click Continue, then go to the main menu Help > Check for updates. Just click Next (right button), the Download (center button), then Next (right button) until the program closes and the update install begins.
I can not over emphasize the importance of accurate error reporting. A fix for this problem was posted in less that 1 hour from the time the problem was verified.
Once again I apologize for any inconvenience.
