HAI UPB PIM to Controller Cable
nwagner
My PIM unit came with no 6-conductor cable to connect to my omnipro II.  Anyone willing to post the pinout or snap a picture of the two terminal ends so that I can make one up?  Thanks in advance!
Welcome to the forum!
Two pictures are attached.  One shows the pinouts for the serial plug on the HAI OPII.  The other one shows what pins they are as they go to a standard 9 pin RS-232 plug (included as an FYI).
Mine are buried today but I did make an HAI UPB PIM to serial connector for my UPB floater a few months ago.
Thanks for the welcome and for posting the pin out. Unfortunately, I need the configuration for the omnipro serial port to PIM cable instead of the computer serial port connection. I should have been more specific in my description. I can't tell if it should be a straight-through or crossover 6-connection wire. Thanks again!
According to HAI customer support (who was very helpful), the cable is a "straight-through" design meaning the colored wires should pair up if you put the plugs facing one another. I made one up with two rj22 plugs and it is working. Hope that helps anyone else in the same boat as me.
