Haiku Haiku - External Access
I am having an issue with Haiku not working from my ipad over the air card. I created two controllers in Haiku one to use when connected to the lan and the other to connect when i am away from home. The lan connection works fine but I can’t get the external connection to work at all. I have a Cisco ASA firewall at home which has logging and I can’t see the Haiku app hitting the firewall. If i put my home ip in the Safari browser i can see it hitting the firewall and I can also ping the firewall with a app I have on the iPad so I know the iPad can communicate. I work in the IT field and work on Cisco products daily so I know I am not doing something wrong with that side. I should see the Haiku app trying to connect in the Cisco log viewer but it never does, any suggestions?
Brian
How are you entering the address? Do not prefix with http://
Try telnet to port 4369 on the external ip as a test.
Looks like Verizon blocks ports I have tested a handfull of ports and can only get 22,23,80,443 to go out on my iPad. Does anyone have an iPad working externaly with a internal Verizon 3g air card? Worst case I can port forward from an open port to 4369.
Brian
Brian
Got it working with the port forward its a shame Verizon blocks so many ports. I have a static ip address on my Verizon cell (corporate setup) and even that has the same ports blocked. I am going to call Verizon since I paid to get static ip's for my users devices and they should not be blocking ports on a static setup.
Brian
